Document Server plugin on IE11
Postby guillaume.houdmon » Thu Feb 16, 2017 8:28 am
We try to integrate a plugin on document server. It works with Chrome, FF, Edge but not with IE 11.
The editor doesn't request the config.json plugin file. There's no JS error or warning and no networks error.
Do plugins work with IE11?
guillaume.houdmon
Re: Document Server plugin on IE11
Postby Maxim » Thu Feb 16, 2017 8:35 am
Hello guillaume.houdmon!
What plugin do you mean? Please specify plugin you've integrated.
Postby shippeli » Fri Feb 17, 2017 2:20 pm
Not solving your problem but FYI: I am just deveolping a plugin and can confirm that it runs also in IE11. So, gerenrally plugins in IE11 work.
Good luck!
shippeli
Postby rafik.haceb » Mon Feb 20, 2017 1:53 pm
Hi;
Like guillaume.houdmon said, custom plugins are not visible on IE11. On Chrome and FF i can see the plugins icon.
rafik.haceb
Postby Maxim » Mon Feb 20, 2017 3:03 pm
We tried to reproduce the issue but have no luck.....
Maybe there is smth wrong with settings of IE11?
Postby guillaume.houdmon » Thu Feb 23, 2017 1:19 pm
I'm looking for if the problem isn't related to a cross-domain constraint.
I'll keep you informed.
guillaume.houdmon
Postby Maxim » Fri Feb 24, 2017 8:14 am
I don't think so, but thank you for keeping us informed.
Postby guillaume.houdmon » Wed May 10, 2017 4:04 pm
I can see my plugin in E11, but it was a hard work.
I've 2 subdomains:
* https://onlyoffice.acme.com
* https://myapp.acme.com
My plugin is hosted at https://myapp.acme.com/plugins/. I add the header Access-Control-Allow-Origin on it.
It's work with all browers ... except IE11. I think it's because the iframe loads the url https://myapp.acme.com/plugins/ (too much croos-domain for IE).
My workaround is to avoid cross-domain with a nginx proxy which proxifies url like https:/onlyoffice.acme.com/myappproxy/(.*) to https://myapp.acme.com/$1
My config is like :
pluginsData: ["https://onlyoffice.acme.com/myappproxy/plugins/config.json"],
My NGINX proxy in /etc/nginx/includes/onlyoffice-document-myappproxy.conf
location ~ ^/myappproxy/(?<fwd_path>.*)$ {
resolver XX.XX.XX.XX;
proxy_pass https://myapp.acme.com/$fwd_path$is_args$args;
proxy_ssl_server_name on;
proxy_set_header Host myapp.acme.com
proxy_redirect off;
guillaume.houdmon
Postby Maxim » Thu May 11, 2017 8:58 am
So and what is your issue?
Postby guillaume.houdmon » Mon May 29, 2017 7:02 am
A lack of documentation ...
guillaume.houdmon
Return to Plugins
