Is it possible to add a plugin to desktop editor on Mac?
Postby sgaluza » Sun Nov 27, 2016 5:16 pm
When I try to add a *.plugin file to a desktop editor on Mac it just doesn't allow to do that (the drag&drop action is not performed). Is it a bug?
sgaluza
Re: Is it possible to add a plugin to desktop editor on Mac?
Postby Maxim » Tue Nov 29, 2016 11:25 am
1 You must have up-to-date desktop Editor
2 Download folder with plugins
3 Enter the folder sdkjs-plugins
4 Choose plugin you need, chess for example
5 Enter the folder Chess and type in terminal zip -r chess.plugin
6 Drop chess.plugin into application
Postby mus » Mon Feb 20, 2017 3:00 pm
Maxims description works for me.
But notice that when you drop the .plugin file onto the app main window, the App doesn't seem to accept the file - there is no visual feedback when you drop the plugin in place, and worse, it seems to snap back to the finder window where you dragged it from.
However, when you then open a document editor, you'll find a new 'plugin' icon in the left most sidebar.
Screen Shot 2017-02-20 at 3.59.00 PM.png (23.73 KiB) Viewed 1919 times
mus
Postby Maxim » Mon Feb 20, 2017 3:19 pm
Hello mus!
Thank you for your comment! The notifications will be added next releases.
Return to Plugins
