Plugin not starting in viewer mode using document server.
Postby brianshaw » Mon Jun 04, 2018 9:13 am
I am using the docker container.
I created a simple copy of the hello world plugin edited to contain just console logs as a test, removed the editing functionality. I have the plugin configured to auto start within the config when building the embed code and have it set to be available in viewer (non editor) mode using "isViewer" set to true.
Am I doing something wrong? I don't even see an option for a plugins icon to try to run the plugin manually when in viewer mode.
When I switch to editor mode the plugin runs automatically and I can also click the plugins icon and runs fine as well.
Any help would be appreciated.
Thanks
Brian
brianshaw
Re: Plugin not starting in viewer mode using document server
Postby Carl » Fri Jun 15, 2018 9:39 am
Hello Brian.
Please send us your plugin, we will analyze the issue.
Return to Plugins
