Plugin autostart
Plugin autostart
Postby lukem » Thu May 24, 2018 11:35 am
(Using online editors)
I have modified 2 example plugins to modify the UI. (attached)
I would like for these plugins to autostart once the editor has loaded and make the changes to the UI.
Following the instructions here https://api.onlyoffice.com/plugin/installation I've added the plugins the the skdjs-plugins directory and updated the default.json with the following.
"plugins": {
        "uri": "/sdkjs-plugins",
        "autostart": [
                "asc.{B62BC2E0-858A-444F-B288-9190DE68B3FE}", #UI Customizer
                "asc.{B62BC2E0-858A-444F-B211-9190DE68B3FE}", #UI Customiser
                "asc.{F5BACB61-64C5-4711-AC8A-D01EC3B2F2E2}" #custom plugin
Looking at the network requests i can see that the plugins.json file contains the following:
    "url":"",
    "pluginsData":[
        "../../../../sdkjs-plugins/interface/config.json", //UI
        "../../../../sdkjs-plugins/pictures/config.json", //Custom
        "../../../../sdkjs-plugins/plugin_valgenesis/config.json" //UI
    "autostart":[
None of the plugins seem to autostart.
is there something i'm doing wrong?
Kind Regards,
Luke
ui plugins.zip
(4.21 KiB) Downloaded 13 times
lukem
Re: Plugin autostart
Postby Carl » Fri Jun 15, 2018 1:00 pm
Hello.
UI customization is not included in standard support case. Please contact our Sales team at sales@onlyoffice.com, they will be glad to inform you about customization services we can provide.
Return to Plugins
