[Doc] Move cursor from plugin
Postby dmockelyn » Mon Mar 26, 2018 6:45 am
I'm writing a plugin that inserts and lists elements into a document. I'd like to be able to "select" a content control when I click on a button in my plugin. The only thing that prevents me from doing so is the ability to change the cursor position.
I read on this forum that there was an undocumented way of moving the cursor. Could you elaboraste on this point ? Or at least give me the name of this method ?
Thanks in advance :)
dmockelyn
Re: [Doc] Move cursor from plugin
Postby Maxim » Fri May 11, 2018 2:06 pm
Hello dmockelyn!
Unfortunately but there is no way to move the cursor for now.
Return to Plugins
