where to get guid if I want to create a plugin
Postby poplee » Wed Mar 14, 2018 3:53 am
Hi guys,
I looked into the script of the current plugins, I found they all have a guid in their conf file, I'm wondering where to get this, any one can help? thanks a lot.
Best,
poplee
Re: where to get guid if I want to create a plugin
Postby Maxim » Wed Mar 14, 2018 9:08 am
Hello poplee!
Do you need guid generator?
Postby poplee » Thu Mar 15, 2018 12:46 am
Is it random that I can makeup one or there's some rules?
anyway, it would be great if I can get a geneater. Thanks
poplee
Postby Maxim » Fri Mar 16, 2018 10:34 am
See here
Postby poplee » Sun Mar 18, 2018 4:12 pm
Great,
Maxim, thanks a lot!
poplee
Postby Maxim » Mon Mar 19, 2018 7:33 am
Hello poplee!
You are welcome!
Return to Plugins
