Show Plugin panel when opening the editor
Postby mmeyer » Mon Feb 26, 2018 5:21 am
We are planing to build a plugin, that our users will need every time they open the editor.
Thus one of the first clicks will always be to open the plugin panel.
Is there a way to open the editor with the plugin panel expanded?
I didn't see anything in the configuration section. Maybe a javascript solution?
Regards,
Michael
mmeyer
Re: Show Plugin panel when opening the editor
Postby Maxim » Mon Feb 26, 2018 1:47 pm
Hello mmeyer!
I advise you to look here
There is no expanded panel.
I hope it will help you.
Postby mmeyer » Mon Feb 26, 2018 2:04 pm
Hello Maxim
Thanks for the reply.
Currently the user needs to click on the "Puzzle icon" on the left to get the list of plugins.
I would like the editor to show the list of plugins by default.
(Without the user having to click on the "Puzzle icon")
In short: I would like the editor to show the plugins like in your link [1] without the user having to click on the plugin icon.
[1] https://api.onlyoffice.com/editors/conf ... #autostart
mmeyer
Postby Maxim » Mon Feb 26, 2018 3:42 pm
Hello mmeyer!
now it's clear for me what you want, but as i know there is no way using APi.
Return to Plugins
