ONLYOFFICE DocumentServer v4.3.3
Document Server releases and description of the update.
Postby Maxim » Wed Jul 05, 2017 1:51 pm
New features
Document Editor
    Special Paste
    Rich text content support
    Translates for Paragraph Styles
    View mode with comments
    Option to hide solved comments
    Abitity to specify custom columns
Spreadsheet Editor
    Formulas with conditional formatting
    Ability to specify custom delimiter for CSV import\export
    Added ACOT, ACOTH, ARABIC, BASE, BETA.DIST, BETA.INV, BETADIST,
    BINOM.DIST, BINOM.INV, CEILING.MATH, CEILING.PRECISE,
    CHIDIST, CHIINV, CHISQ.DIST, CHISQ.DIST.RT,
    CHISQ.INV, CHISQ.INV.RT, COMBINA, CONCAT, CONFIDENCE.NORM,
    CONFIDENCE.T, COT, COTH, CSC, CSCH, DECIMAL, EXPON.DIST, F.DIST,
    F.DIST.RT, F.INV, F.INV.RT, FDIST, FINV, FLOOR.MATH,
    FLOOR.PRECISE, GAMMA, GAMMA.DIST, GAMMA.INV, GAMMA.PRECISE,
    GAMMADIST, GAMMAINV, GAUSS, IFNA, IMCOSH, IMCOT, IMCSC,
    IMCSCH, IMSEC, IMSECH, IMSINH, IMTAN, ISO.CEILING,
    LOGNORM.DIST, LOGNORM.INV, NUMBERVALUE, PERCENTILE.EXC, PERCENTILE.INC,
    PERCENTRANK.EXC, PERCENTRANK.INC, RANK, RANK.AVG, RANK.EQ, SEC, SECH,
    T.DIST, T.DIST.2T, T.DIST.RT, T.INV, T.INV.2T, TDIST, TINV, XOR formulas
    Exclude hidden rows from copy, autofill, formatting etc...
    Update active cell color
    Frozen pane now with shadow
    Translates for cell styles
    Search and replace by select
    Abitity to specify bullets and numbering for text in shape.
    Ability to specify columns for Text Areas
    Ability to add the connectors for the shapes
    Support Shift+Delete, Ctrl+Insert and Shift+Insert for Cut-Paste
Presentation Editor
    Ability to connect shapes via lines
    Ability to create bullet and number lists in the shapes
    Spellcheker in Presentation Editor
    Ability to download as ODP
Plugins
    New type for plugin window (without borders, shadows, buttons)
x2t
    Speedup for opening ooxml: windows 200%, linux 20%
    Better convertation from/to RTF
    Better support of password protected ooxml, binary ms
    Support of password protected ppt
Return to Document Server
