File icons on mac with editors
Suggestions on website/support/API etc.
Postby nommaz » Fri Feb 17, 2017 8:26 am
Hello
I changed editors to handle *.docx but file icons are blank. I would like to see Onlyoffice icon or document/sheedt/pres icon if possible. The info.plist file just shows a reference to
      <dict>
         <key>CFBundleTypeIconFile</key>
         <string>file-rtf</string>
         <key>CFBundleTypeName</key>
         <string>Text</string>
         <key>CFBundleTypeRole</key>
         <string>Editor</string>
         <key>LSItemContentTypes</key>
         <array>
            <string>public.text</string>
         </array>
      </dict>
so looks correct but doesnt work
nommaz
Re: File icons on mac with editors
Postby Maxim » Fri Feb 17, 2017 12:23 pm
Hello nommaz!
Thanks for notification! We've found bug!
