Resoulation problem on OO Desktop Editors (
Suggestions on website/support/API etc.
Postby koksalbasar » Fri Feb 10, 2017 8:33 pm
I've download your desktop software. But I've an resolution issue. I've been using dual monitor. First one is 2160x1440 and the second one is 2560x1080. When I drag the second one your software screen is changing. It's not usable. (Full screen or sized window, the result was not changed. The first screen is ok for the any size.) I added a picture. May be you want to check this issue.
Thank you
Re: Resoulation problem on OO Desktop Editors (
Postby Maxim » Mon Feb 13, 2017 10:23 am
Hello koksalbasar!
Thank you for the notification.
I tried to reproduce your issue but i have no luck. It would be nice to attach screenshots to the folowing info
- build OS and OnluOffice Desktop Editor
- model of monitors and videocards (driver version)
- scaling factor
