A few suggestions
Suggestions on website/support/API etc.
A few suggestions
Postby HM-Mike » Thu Jul 28, 2016 8:47 pm
I've posted in this forum and it's a suggestion of OnlyOffice overall, not each specific part.
1.You need to do more with the RPM/Deb versions, provide versions for all of it so it can be done via RPM/Deb rather than just docker. In recommending Docker, you are forcing people to learn 2 systems, 1 being docker, the other being your own software, I get it's easier for you to deploy but it's not easier for people who have never used docker.
2. Your one-click installer doesn't recognize 64bit CentOS 7 even though this is now using the 3.10 kernel as you recommend/require, when trying to install on CentOS 7, it returns saying that we must use 64bit OS but it is. Again, emphasizing on the learning 2 systems, you're forcing people to learn ubuntu/debian when their preferred operating system may be CentOS, all Linux are the same but do act differently.
3. For those of us that aren't familiar with Docker and not many people are, provide more documentation on this so we can understand how to do things more.
Thanks,
Mike
HM-Mike
Re: A few suggestions
Postby Dean » Thu Aug 04, 2016 11:47 am
Hello, Mike,
thank you for sharing your opinion.
Now, However, the source code of the app is available on GitHub, so the one can build it. Also the deb-packages are available on Sourceforge and on our website
deb-package of Document Server: https://sourceforge.net/projects/teamla ... /binaries/
both rpm and deb-packages of Community Server: https://sourceforge.net/projects/teamla ... /binaries/
https://github.com/ONLYOFFICE/CommunityServer/
https://github.com/ONLYOFFICE/DocumentServer
Postby HM-Mike » Thu Aug 04, 2016 7:41 pm
Why is there no RPM version for the documents?
Thanks,
Mike
HM-Mike
