Mail server using Docker : Connection refused
Suggestions on Mail Server Installation/Functionality
Re: Mail server using Docker : Connection refused
Postby Zegorax » Mon Mar 27, 2017 3:32 pm
Here's the database result :
mysql> SELECT * FROM mail_server_server t limit 1;SELECT * from mail_mailbox_server t WHERE t.id in (@smtpId, @imapId);
| id | mx_record  | connection_string        | server_type | smtp_settings_id | imap_settings_id |
|  1 | b.ch | {"DbConnection" : "Server=onlyoffice-mail-server;Database=onlyoffice_mailserver;User ID=mail_admin;Password=Isadmin123;Pooling=True;Character Set=utf8;AutoEnlist=false", "Api":{"Protocol":"http", "Server":"onlyoffice-mail-server", "Port":"8081", "Version":"v1","Token":"d5d56b44bff53511949179ae79fb61bb"}} |           2 |             1000 |              999 |
1 row in set (0.00 sec)
| id   | id_provider | type | hostname   | port | socket_type | username       | authentication | is_user_data |
|  999 |          -1 | imap | b.ch |  143 | STARTTLS    | %EMAILADDRESS% |                |            0 |
| 1000 |          -1 | smtp | b.ch |  587 | STARTTLS    | %EMAILADDRESS% |                |            0 |
Zegorax
Postby Maxim » Tue Mar 28, 2017 7:39 am
Hello Zegorax!
At first sight it's all good. I think you should check DNS configuration. Maybe smth. wrong with DNS parametrs.
Let's check, you need application DIG and TELNET. Install it in the community container.
Enter community container and execute command
dig b.ch MX
dig b.ch ANY
also use telnet to try to access to domain b.ch
open b.ch 143
if it's ok you will see
+OK
USER l@b.ch
+OK
Postby Zegorax » Tue Mar 28, 2017 7:52 am
Okay, you can check the DNS settings with the following domain : bde-arc.ch
I think everything is right. I don't know why it doesn't work. There's a NAT because I have only one IP, but I redirected everything correctly with iptables.
I can telnet the SMTP and IMAP on port 25 and 143 from the outside. Can you check that configuration ?
EDIT : I see now your edited post, I'll try that as soon as I can
Zegorax
Postby Zegorax » Tue Mar 28, 2017 8:18 am
Here's the dig any :
>> DiG 9.9.5-3ubuntu0.10-Ubuntu <<>> bde-arc.ch ANY
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 43819
;; flags: qr rd ra; QUERY: 1, ANSWER: 4, AUTHORITY: 2, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;bde-arc.ch.                    IN      ANY
;; ANSWER SECTION:
bde-arc.ch.             3789    IN      HINFO   "ANY obsoleted" "See draft-ietf-dnsop-refuse-any"
bde-arc.ch.             245     IN      MX      0 bde-arc.ch.
bde-arc.ch.             3545    IN      NS      terry.ns.cloudflare.com.
bde-arc.ch.             3545    IN      NS      brit.ns.cloudflare.com.
;; AUTHORITY SECTION:
;; Query time: 9 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Tue Mar 28 10:13:07 CEST 2017
;; MSG SIZE  rcvd: 197
Here's the dig MX :
<>> DiG 9.9.5-3ubuntu0.10-Ubuntu <<>> bde-arc.ch MX
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 35402
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 1
;bde-arc.ch.                    IN      MX
;; ANSWER SECTION:
bde-arc.ch.             300     IN      MX      0 bde-arc.ch.
bde-arc.ch.             3600    IN      NS      terry.ns.cloudflare.com.
bde-arc.ch.             3600    IN      NS      brit.ns.cloudflare.com.
;; Query time: 342 msec
;; WHEN: Tue Mar 28 10:12:12 CEST 2017
;; MSG SIZE  rcvd: 111
The command open does not do anything
Zegorax
Postby Maxim » Tue Mar 28, 2017 8:28 am
Zegorax
Where is the connection between b.ch and bde-arc.ch?
It is all okey with bde-arc.ch, but you posted your issue with b.ch.
b.ch doesn't exist, but this domain in your database.
I'm confused now.
Postby Zegorax » Tue Mar 28, 2017 8:30 am
Yes, I renamed in the posts for confidentiality purposes, but finally I don't care, everything you saw with b.ch is bde-arc.ch, and l@b.ch is Luca.verardo@bde-arc.ch
Sorry for that misunderstanding !
Zegorax
Postby Maxim » Tue Mar 28, 2017 8:38 am
:lol: :lol: :lol:
Ok, if it's clear now let's continue ))))
Connection still refused?
Postby Zegorax » Tue Mar 28, 2017 8:41 am
No I can telnet successfully into the 143, however I don't know how to get the result with the +OK
Zegorax
Postby Maxim » Tue Mar 28, 2017 8:53 am
Try to change 1000 and 999 records where hostname is bde-arc.ch (b.ch) to onlyoffice-mail-server
Update mail_mailbox_server t SET t.hostname = 'onlyoffice-mail-server' WHERE t.id in (999,1000);
Postby Zegorax » Tue Mar 28, 2017 9:10 am
In the mail docker container, or in the community one ?
Zegorax
PreviousNext
Return to Mail Server
