Problem to install Mail Server
Suggestions on Mail Server Installation/Functionality
Postby Jejouille » Fri Mar 10, 2017 4:26 pm
Hi all,
I configured iptables on Debian 8 to install mail server but it's not working.
I don't know where is the problem.
My server is a virtual private server at OVH.
http://nsa37.casimages.com/img/2017/03/10/170310054720216691.png
Regards.
Jejouille
Re: Problem to install Mail Server
Postby Maxim » Mon Mar 13, 2017 7:42 am
Hello Jejouille!
1 Try to delete all iptable rules.....or to stop firewall type the following commands
iptables -F
iptables -X
iptables -t nat -F
iptables -t nat -X
iptables -t mangle -F
iptables -t mangle -X
iptables -P INPUT ACCEPT
iptables -P OUTPUT ACCEPT
iptables -P FORWARD ACCEPT
And try to insatll again.
2 Try to install Community Edition with provided script. If you need Mail Server do not forget specify domain.
bash opensource-install.sh -md "yourdomain.com"
This will install all the Community Edition components including Mail Server with the yourdomain.com domain name specified.
Your domain that will be used for maintaining correspondence must be valid and configured for this machine (i.e. it should have the appropriate A record in the DNS settings that points your domain name to the IP address of the machine where Mail Server is installed).
In the command above, the "yourdomain.com" parameter must be understood as a service domain for Mail Server. It is usually specified in the MX record of the domain that will be used for maintaining correspondence. As a rule, the "yourdomain.com" looks like mx1.onlyoffice.com
Return to Mail Server
