How to copy shown cells in spreadsheet with filter
Postby nagios.msff.rsp » Tue Apr 18, 2017 8:03 am
I am using
4.3.1.4
I see you guys have implement new paste features, thank you for that.
I still have an issue when I make spreadsheet and use filters, then I want to copy the results for exampe:
I have excel with column that contain either 1 or 0 with total of 10 records for both
And when I filter the 1 column, I get 3 records
When I drag and copy those 3 columns and paste them I get 7 records pasted, why cause the copy also takes the hidden data like records with 0 in between the copy
MS Excel handles this automatically or you need to press Find & Select --> Go To Special --> Visible Cells only
Can you please look into this ?
Many Thanks.
nagios.msff.rsp
Re: How to copy shown cells in spreadsheet with filter
Postby Maxim » Tue Apr 18, 2017 12:38 pm
Hello nagios.msff.rsp!
We have detected the bug! Thank you for error notification!
Return to Document Server
