New features ?
New features ?
Postby vent » Fri Jan 20, 2017 1:26 pm
I have some new questions and possibly new features:
a) Can we change the default date format (from mm/dd/yyyy to dd/mm/yyyy) ?
b) On the browser tabs displays only ONLYOFFICE™. Can we add also the name of the file ?
c) Can we have "links" between documents ?
d) I have version 4.1 installed. How can I upgrade to 4.2.5 ? I tried suggestions from https://helpcenter.onlyoffice.com/serve ... mentServer with no luck.
Thanks in advance.
vent
Re: New features ?
Postby Maxim » Mon Jan 23, 2017 7:58 am
Hello vent!
Unfortunately you can't change date format and add name of file into browser tab, but thanks for the idea. And files can't be linked.
Please specify errors you faced upgrading Document Server or what went wrong while you were trying to upgrade.
Discribe please why you didn't upgrade Document Server.
Re: New features ?
Postby vent » Thu Jan 26, 2017 2:25 pm
Hi Maxim thank for your reply.
apt-get update displays:
Err http://download.onlyoffice.com squeeze/main amd64 Packages
404 Not Found [IP: 54.192.37.99 80]
and if I try to upgrade there is nothing new.
My /etc/apt/sources.list file is:
deb http://security.debian.org/ jessie/updates main
deb-src http://security.debian.org/ jessie/updates main
deb http://httpredir.debian.org/debian jessie-updates main contrib
deb http://httpredir.debian.org/debian jessie main
deb http://archive.ubuntu.com/ubuntu precise main universe multiverse
deb http://download.onlyoffice.com/repo/debian squeeze main
deb https://deb.nodesource.com/node_4.x precise main
# deb-src https://deb.nodesource.com/node_4.x precise main
Thanks in advance
vent
Re: New features ?
Postby Maxim » Fri Jan 27, 2017 7:19 am
Try "https" instaed of "http"
Re: New features ?
Postby vent » Mon Jan 30, 2017 2:09 pm
Thank you. I had to put:
Acquire::https {
Verify-Peer "false";
Verify-Host "false";
inside /etc/apt/apt.conf
since I had the error:
W: Failed to fetch https://download.onlyoffice.com/repo/de ... 4/Packages SSL: certificate subject name (*.cloudfront.net) does not match target host name 'download.onlyoffice.com'
Now the apt-get upgrade doesn't display any errors:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages have been kept back:
onlyoffice-documentserver
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
and the version remains to 4.1. The dist-upgrade displays:
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
When I tried to install it with:
sudo apt-get install onlyoffice-documentserver
it displays:
onlyoffice-documentserver : Depends: nodejs (>= 6.9.1) but 4.7.2-1nodesource1~precise1 is to be installed
vent
Re: New features ?
Postby Maxim » Tue Jan 31, 2017 7:55 am
So, as i think you've installed update with no errors?
Return to Document Server
