Is it possible directly open XLSX with defined sheet?
Postby BranKo » Fri Jan 13, 2017 1:12 pm
I mean that I have XLSX workbook with many sheets (one per week in year). I want to define which sheet is wanted to open (for next week).
Because last save of this workbook wasn't on this sheet.
I can't find if this possibility is supported or or not. I'm newbie in OnlyOffice. Thanks.
BranKo
Re: Is it possible directly open XLSX with defined sheet?
Postby Maxim » Fri Jan 13, 2017 2:10 pm
Hello BranKo!
OnlyOffice supports opening XLSX workbook with the last opened sheet in workbook. But we had bug with that feature and we will fix it next release.
Return to Document Server
