Doc server stuck loading
Postby dgallig » Tue Dec 20, 2016 7:03 pm
after installing the doc server , when loading a doc, I get the page "loading document" and aveerything is stuck.
I followed those instructions :
echo "deb http://archive.ubuntu.com/ubuntu precise main universe multiverse" | sudo tee -a /etc/apt/sources.list
curl -sL https://deb.nodesource.com/setup_6.x | sudo bash -
sudo apt-get install postgresql
sudo -u postgres psql -c "CREATE DATABASE onlyoffice;"
sudo -u postgres psql -c "CREATE USER onlyoffice WITH password 'onlyoffice';"
sudo -u postgres psql -c "GRANT ALL privileges ON DATABASE onlyoffice TO onlyoffice;"
sudo apt-get install redis-server
sudo apt-get install rabbitmq-server
wget http://download.onlyoffice.com/repo/onlyoffice.key
sudo apt-key add onlyoffice.key
echo "deb http://download.onlyoffice.com/repo/debian squeeze main" | sudo tee -a /etc/apt/sources.list
sudo apt-get update
sudo apt-get install onlyoffice-documentserver
my nginx conf is :
include /etc/nginx/includes/onlyoffice-http.conf;
server {
  listen 0.0.0.0:80;
  listen [::]:80 default_server;
  server_tokens off;
  listen 443 ssl;
  #error_page 404 /404.html;
  #error_page 500 502 503 504 /50x.html;
server_name office.example.com;
ssl_certificate /etc/letsencrypt/live/office.example.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/office.example.com/privkey.pem;
  include /etc/nginx/includes/onlyoffice-documentserver-*.conf;
Any idea?
Many thanks in advance
dgallig
Re: Doc server stuck loading
Postby Maxim » Wed Dec 21, 2016 7:57 am
PLease describe how did you try to load doc? You installed Document Server following this tutorial and you have Community Server or you try to integrate it into your own document management system using the provided API?
Return to Document Server
