Owncloud editor plugin
Postby nommaz » Wed Dec 14, 2016 5:47 am
Hello
I heard you are developing editor plugins for owncloud. I cannot wait to try them, which page should i monitor to get them as soon as they are out?
is it this one: https://api.onlyoffice.com/editors/plugins
Vedat
nommaz
Re: Owncloud editor plugin
Postby John » Thu Dec 15, 2016 10:20 am
Hello, Vedat!
We plan to release plugins for ownclowd but we can't define contcrete terms for that now.
You may monitor the above mentioned page. Also we will inform about the release in the section 'Announcements'.
Thank you for the interest in our product.
John
Postby nommaz » Sat Feb 04, 2017 10:34 am
Hi John
Very happy to see the ownCloud plugin released. I would like to use with nextcloud which is on version 11 but the plugin wont accept installations above version 10.
How can I remove the version check on the plugin and see if it maybe works?
nommaz
Return to Document Server
