Save modifications when you have connection problem
Postby dsi-lille » Mon Nov 28, 2016 8:24 am
when you lose your internet connection, you can still edit your file.
But when the internet connection return, an error appear : "Cannot access file" and the modification are not save.
It could be useful, if when the internet connection came back, the modifications are save.
Also, if the user could be warn when the internet connection goes off.
thanks,
Yoann
dsi-lille
Re: Save modifications when you have connection problem
Postby Maxim » Mon Nov 28, 2016 10:08 am
Thank you for your feedback!
Return to Document Server
