Insert summary inside document
Postby maumar » Tue Jun 14, 2016 3:36 pm
I've not found a way to insert an automatic summary inside docx from Document Server. Is this feature supported?
If not, it is in the roadmap?
I think Summary is a mandatory feature to allow online editing of existing MSOffice and LibreOffice documents in an Enterprise environment
maumar
Re: Insert summary inside document
Postby Dean » Thu Jun 16, 2016 2:56 pm
Would you kindly describe what you mean by 'Summary'?
Postby maumar » Wed Jun 29, 2016 12:28 pm
I mean "Table of contents"
maumar
Postby downunder » Wed Oct 19, 2016 3:43 am
I too would like to know if a TOC is on the radar, and even character styles? Would love to be able to insert variables (styleRef) in header and have styles presented as drop-down list or in right pane.
downunder
Postby rashel » Sat Oct 22, 2016 5:19 pm
I have exactly the same question!
It's not possible to work on a document without a "summary", and I'm very hurry to find it to begin to really use OnlyOffice, me and my team. I also would like to write about this solution on my blog, because it's full of interesting possibilities, but it just miss some simple basic things like the summary ...
User avatar
rashel
Postby nommaz » Sun Jan 01, 2017 11:12 am
Google has a reduction function version which gets the job done. Hope you can add ToC function soon. Maybe a plugin can be developed for it?
If it can be implemented as a part of core document editor a side benefit would be to send links to particular sections or comments in a doxument. This can be a very valuable benefit on its own especially when collaborating on big files.
nommaz
Postby Maxim » Tue Jan 03, 2017 8:08 am
Thank you nommaz for your suggestion! It's very important for us that you're taking part to make OnlyOffice better!
Postby mus » Tue Jan 31, 2017 3:29 pm
Isn't that a feature that could be implemented as a plugin?
BTW the API documentation seems a little incomplete. Can you tell us more about the status?
mus
Postby Maxim » Wed Feb 01, 2017 7:42 am
Till now there is no such function but our developers are going to implement it.
Postby dsi-lille » Wed Nov 15, 2017 3:01 pm
Hello Maxim,
is this feature still on the to do list ?
Thanks,
Yoann
dsi-lille
Next
Return to Document Server
