change number of format decimal and thousand
Postby btoygar » Mon Nov 10, 2014 5:50 pm
How can i change number of format decimal to ',' and thousand to '.' in Excel online editors
For example 12,000,000.12 (to) ---> 12.000.000,12
Best regards
btoygar
Re: change number of format decimal and thousand
Postby Dean » Wed Nov 12, 2014 3:08 pm
No, unfortunately there is no xuch a function in the current ONLYOFFICE version. Your idea was forwarded to our developers' team and will be considered by all means.
Postby pee » Wed Nov 19, 2014 1:46 am
I would add to this suggestion, that it should be possible to change all formats (date, time, currency etc) and this for the whole onlyoffice (also in calendar and projects and crm etc.)
Thanks
pee
Return to Document Server
