Adjust the size in the presentation tool
Postby dairaine » Sat Sep 29, 2018 9:17 am
the font size management in powerpoint is quite simple and efficent. There are 2 basic functions to quickly adapt the size in a slide:
- a button to increase / reduce all the characters in proportion to their respective size
- an automatic mode adjusting the size according to the possible place on the slide.
I do not see these functions in onlyoffice. There seems to be only the possibility to adjust the size in an absolute way, quite complicated to quickly reduce the whole slide with characters of different sizes.
An idea ?
dairaine
Re: Adjust the size in the presentation tool
Postby Maxim » Fri Oct 05, 2018 9:37 am
Hello dairaine!
An idea ?
There is a possibility to change the font size only.
Return to Document Server
