CTRL + Insert doesn't work like CTRL + C
Postby fre.ant » Tue Jun 05, 2018 1:31 pm
I'm one of the alien who use "CTRL + Insert" to copy and "Shift + Insert" to past.
"CTRL + Insert" doesn't work :cry:
"Shift + Insert" work
Could you correct that in a futur update ? ;)
Best regards
fre.ant
Re: CTRL + Insert doesn't work like CTRL + C
Postby fre.ant » Thu Jun 07, 2018 7:26 am
"Shift + delete" must respond like "CTRL + X" too.
Best regards
fre.ant
Postby Alexander_mb » Fri Jun 15, 2018 6:40 am
Hello fre.ant,
Please specify the version of the Document Server you use and its installation type (Docker or DEB/RPM), so we reproduce the mentioned issue. Specify also what exact product of ONLYOFFICE you use (Community Edition, Enterprise Edition, Integration Edition or Developer Edition).
Alexander_mb
Return to Document Server
