Change port
Change port
Postby simsala » Thu May 31, 2018 3:20 pm
Is it possible to change port 8000 for DocService? This port is already occupied by another application that has not yet provided any possibility to change it. I installed OnlyOffice via the repository.
Update: I tried it with
echo onlyoffice-documentserver onlyoffice/docservice-port select 8005 | sudo debconf-set-selections
and did reboot the server, but it did not have any impact.
Update2:
Okay, I figured out how to change the port. The above command probably only works with a new installation. An existing installation can be modified by modifying the following two files:
1. /etc/onlyoffice/documentserver/default.json
Replace line 53
"port": 8000,
with
"port": 8005,
if your new port is 8005
2. /etc/onlyoffice/documentserver/nginx/includes/onlyoffice-http.conf
Replace
upstream docservice {
  server localhost:8000;
with
  server localhost:8005;
simsala
Re: Change port
Postby Maxim » Fri Jun 01, 2018 6:50 am
Hello simsala!
Yes and you have posted the solution.
Return to Document Server
