Installing
Installing
Postby fre.ant » Thu May 17, 2018 10:10 am
I'm following the font installation procedure here : https://helpcenter.onlyoffice.com/de/se ... fonts.aspx
My font "Calibri" is in /usr/share/fonts/truetype/calibri
524751    4 drwxr-xr-x 2 root root    4096 mai 17 11:49 .
536062    4 drwxr-xr-x 4 root root    4096 mai 17 11:29 ..
524755 1504 -rwxrwxrwx 1 root root 1539586 mai 17 11:48 CALIBRIB.TTF
524757 1096 -rwxrwxrwx 1 root root 1119622 mai 17 11:48 CALIBRII.TTF
524763 1340 -rwxrwxrwx 1 root root 1371367 mai 17 11:49 calibril.ttf
524753 1536 -rwxrwxrwx 1 root root 1571230 mai 17 11:48 Calibri.ttf
524764 1056 -rwxrwxrwx 1 root root 1079650 mai 17 11:49 CALIBRIZ.TTF
onlyoffice:/usr/share/fonts/truetype/calibri$
I run the documentserver-generate-allfonts.sh
onlyoffice:/usr/bin$ sudo documentserver-generate-allfonts.sh
Generating AllFonts.js, please wait...Done
onlyoffice-documentserver:docservice: stopped
onlyoffice-documentserver:docservice: started
onlyoffice-documentserver:converter: stopped
onlyoffice-documentserver:converter: started
Clear the web browser cache, but the Colibri font doesn't appear in the font list :(
fre.ant
Re: Installing
Postby Maxim » Mon May 21, 2018 8:23 am
Hello fre.ant!
Specify please your Document Server version and type of installation (RPM/DEB, docker).
A couple of days i checked this instruction and found no errors.
Re: Installing
Postby fre.ant » Tue May 22, 2018 7:36 am
i use the RPM/DEB 5.1.3 in demo mode on Ubuntu 16.04.4 LTS.
Best regards
fre.ant
Re: Installing
Postby Maxim » Wed May 23, 2018 1:36 pm
Hello fre.ant!
Just now i have checked on Ubuntu 16.04.4 LTS with RPM/DEB Document Server 5.1.3 and this instruction works like it should
Return to Document Server
