Update overwrites webserver config
Postby Nepu » Sat Mar 24, 2018 11:18 pm
I know apt can keep the existing version.
Please configure the package correctly so that it doesn't overwrite /etc/nginx/conf.d/onlyoffice-documentserver.conf.
Nepu
Re: Update overwrites webserver config
Postby Maxim » Mon Mar 26, 2018 6:43 am
Hello Nepu!
Please specify version of the Document Server and what instruction you followed to install it.
Also it would be great if you describe how you found out that onlyoffice-documentserver.conf. was overwritten.
Postby Nepu » Tue Mar 27, 2018 4:21 pm
Hello Maxim,
I updated from 5.0.4 to 5.0.7 with "apt-get update && apt-get dist-upgrade -y".
That's all I did, just standard system upgrades.
Nepu
Postby Maxim » Tue Apr 03, 2018 8:15 am
You're right! We will try to solve it.
Return to Document Server
Users browsing this forum: Google [Bot] and 2 guests
