DocumentServer: Changing default document language
Postby mmeyer » Fri Mar 09, 2018 8:45 am
I am using the DocucmentServer.
When a new document is opened the language of the document and of the spellchecker are always set to "English (United States)".
Having to change this each time a new document is opened is very cumbersome.
Is there a way to set the language per document? E.g by
- Using the javascript api? (https://api.onlyoffice.com/editors/config/)
- By setting a parameter in the documentUrl? https://api.onlyoffice.com/editors/config/document#url
- By setting a header attribute in the documentUrl? https://api.onlyoffice.com/editors/config/document#url
Or can I at least change the default document-language and spellchecker-language in a config file?
Note: I already changed the language of the editor using https://api.onlyoffice.com/editors/config/editor#lang
Regards,
Michael
mmeyer
Re: DocumentServer: Changing default document language
Postby Maxim » Fri Mar 09, 2018 10:55 am
Hello mmeyer!
You need to change the example doc file. When you create a doc it means that document server opens an example empty file.
Postby mmeyer » Mon Mar 12, 2018 5:07 am
Hello Maxim
Thanks for the reply.
I wasn't aware that OnlyOffice was able to read the language from the document metadata.
When opening a word document with language set to de_CH the OnlyOffice editor sets the language correctly. Nice!
Unfortunately the language of the spellckecker is still "Engish (United states)".
It would be nice if the spellckecker would use the document language by default.
(Being able to set the default spellchecker language in the editor configuration would also be an acceptable solution).
Is this possible?
Regards,
Michael
mmeyer
Return to Document Server
