error = errorId = Update Version error
Postby cooperbr » Wed Dec 27, 2017 7:18 pm
Good afternoon, I have installed the document server on a ubuntu 16.
integrated with nextcloud.
when I edit spreadsheets, some information is lost, and in the onlyoffice log I check these lines at the time the information disappeared.
2017-12-26 14: 17: 07.716] [ERROR] nodeJS - error description: docId = 4162770_1513977544 errorId = Update Version error
[2017-12-27 05: 28: 14.826] [ERROR] nodeJS - error description: docId = 4162770_1514320461_2 errorId = Update Version error
[2017-12-27 07: 05: 48.326] [ERROR] nodeJS - error description: docId = 4162770_1514359692_3 errorId = Update Version error
any procedure for error correction?
tnk
cooperbr
Re: error = errorId = Update Version error
Postby Maxim » Sat Dec 30, 2017 8:12 am
Hello cooperbr!
Do you use two separate servers? One for Nextcloud and another one for Document Server? What instruction you followed to install?
Return to Document Server
