what happens with the folder common and main?
Postby yisusflow » Wed Dec 06, 2017 4:46 pm
Start the document server using docker, because I can not compile the dependencies and then the code, now I want to modify the file Toolbar.template that is in the following route: documenteditor/mobile/app/template/Toolbar.template' entering the container I get the surprise that does not exist
yisusflow
Re: what happens with the folder common and main?
Postby Maxim » Thu Dec 07, 2017 8:04 am
Hello yisusflow!
Do you need this file one?
Postby yisusflow » Tue Dec 12, 2017 1:57 am
because ? i am very confused, in my compilation in VM ubuntu 14.3 find error in deploy ....when eject a instructions of cd ../sdkjs && make .
running "deploy-app-main" task
Task "imagemin" not found. Use --force to continue .
Aborted due to warnings.
make: *** [../web-apps/deploy/web-apps/apss/documenteditor/main/app.js] Error 3 .
What happen?
yisusflow
Postby Maxim » Tue Dec 12, 2017 5:53 am
Hello yisusflow!
What happen?
I cannot say.
Postby yisusflow » Wed Dec 13, 2017 12:44 am
in my compilation in vm of step cd ../sdkjs && make......
is Aborted due to warning.
make: *** [../web-apps/deploy/web-apps/apps/documenteditor/main/app.js] Error 3
My ubuntu server ubuntu-14.04.5-server-amd64
My version npm 1.3.10
My version nodejs 0.10.25
yisusflow
Return to Document Server
