unable to save settings for page settings
Postby nudoc » Sat Dec 02, 2017 1:47 pm
everything works fine with onlyoffice,
except with spreadsheet page settings, I can not save any changes, which is disturbing to turn into pdf, to have only one page.
and also when someone opens my shared file he has this message: the document could not be saved ... image attached
onlyoffice document runs on a docker container: onlyofficedocumentserver1
Have you ever had this problem ?
do you know how to fix it? '
Thank you in advance for your answer
nudoc
Re: unable to save settings for page settings
Postby Maxim » Mon Dec 04, 2017 7:13 am
Please specify what instruction you followed to install Onlyoffice. Also please attach screenshot (not mobile photo) with Document Service Location in Settings.
Postby nudoc » Wed Dec 06, 2017 5:17 pm
hello,
thanks for your answer
The document could not be saved .. : the problem is solved, thanks
for installation,
I followed the documentation of the docker container https://hub.docker.com/r/onlyoffice/documentserver/
but I did not export the configuration files out of the application, I have the container that runs, with a domain name redirection, that I filled in on my website, I do not know if I Am I clear enough ...?
Also please attach screenshot (not mobile photo) with Document Service Location in Settings :
I'm sorry, but I did not understand the meaning of your question about the screen shot you want, wich location...?
Thank you very much for your answer
nudoc
Postby Maxim » Thu Dec 07, 2017 8:02 am
Hello nudoc!
It's great that you solved the issue
Postby nudoc » Fri Dec 08, 2017 10:26 am
hi,
Hello nudoc!
-no, I did not solve the main problem!
for installation,
Also please attach screenshot (not mobile photo) with Document Service Location in Settings:
I'm sorry, but I did not understand the meaning of your question about the screen shot you want, wich location ...?
nudoc
nudoc
Postby nudoc » Sun Dec 10, 2017 10:25 am
hi,
I think that all my errors, of not being able to record, come from the problem of resolution of the websocket, indeed I went to see in all possible aids and I do not find an answer to this problem.
help me... thanks !
nudoc
Postby Maxim » Tue Dec 12, 2017 7:44 am
Hello nudoc!
Did you install Onlyoffice Document Server only?
Postby nudoc » Sat Dec 16, 2017 11:36 am
thanks for your reply, yes only onlyoffice document server ...
thank you
nudoc
Postby Maxim » Mon Dec 18, 2017 10:09 am
Hello nudoc!
I that case you should see our API "How to"
Postby nudoc » Tue Dec 19, 2017 9:06 am
Hello, thank you for your answer
I went to see your link, very very complicated for me this configuration ...
I do not have access to the only office files because I have not been able to export the configuration and application files, so I can not reach json and other ...
My question, do I have to export my onlyoffice document server configuration files or it is not mandatory? because I do not know enough ssh language command line.
Is it possible to help me on the way forward in a simpler way?
thanks in advance for your help
nudoc
Next
Return to Document Server
