Maybe I am mistaken, but wasn't the update to Document Server 5.0 supposed to be different looking? Kinda like MS OFfice with tabs for navigation?
I have a Nextcloud implementation with the integration app (1.1.5) and a brand new install of OnlyOffice document server 5.0.3. It is running great but when I look at the appearance of 5.0.3 on the OnlyOffice website it looks very different.
THe onlyoffice on the following link:
https://www.onlyoffice.com/
Look different than the look I am still experiencing here: (pulled this image from Google images)
http://cdn.itzgeek.com/wp-content/uploa ... Editor.png
If you do not want to click on an external link above, then you can refer to any 4.X.X version or below. There are no tabs at the top for File, Home, Insert, Plugins
Is this because I am using 5.0.3 as a nextcloud integration and not via OnlyOFfice Community server?
