Verify my document server is registered
Postby RKD-IT » Mon Nov 13, 2017 6:51 pm
I have the file license.lic which was sent to me once we purchased the Enterprise edition of OnlyOFfice in the folder /var/www/onlyoffice/Data. I even chown'd the file for the user:group "onlyoffice" and set chmod 755
How can I verify that the server knows the license is applied?
RKD-IT
Re: Verify my document server is registered
Postby Maxim » Fri Nov 17, 2017 11:04 am
Hello RKD-IT
Go to "Payments" page and check the information. It should be like this one
    You are using ONLYOFFICE Enterprise Edition. Support and updates will be disabled on 08 October 2018.
    Number of active users you've added: 2/50
    Number of portals you've created: 1/1/
Return to Document Server
