Presentation: align objects to each other
Postby joachimnielandt » Mon Oct 16, 2017 12:47 pm
Hello all,
I'm currently trying out onlyoffice in a local installation to see whether it can be used in our private corporate environment. One feature that seems to be eluding me is that it's only impossible to align objects to each other (for example, select 5 objects and 'align left', which would set the x coordinate of all the objects to the minimum x coordinate of the 5). Right now, if I choose 'align left', the tool aligns everything to the slide instead.
Am I missing something obvious?
joachimnielandt
Re: Presentation: align objects to each other
Postby Maxim » Tue Oct 17, 2017 7:47 am
Hello joachimnielandt!
Attach screenshot please!
Postby joachimnielandt » Fri Oct 20, 2017 8:27 am
Hi Maxim,
I hope this illustrates the problem graphically:
joachimnielandt
Postby Maxim » Fri Oct 27, 2017 8:36 am
Thank you for the information! We have detected the problem.
The problem of incorrect alignment of auto-figures is actual for editors of documents and tables
Return to Document Server
