Better freezing options
Postby RKD-IT » Thu Sep 28, 2017 6:39 pm
I can see there is a freeze pane but is there a way to freeze row or freeze column? If not is there any chance to see this feature in the near future?
3 years ago you guys were working on a function buit I can't seem to find anything better than freeze pane
viewtopic.php?f=7&t=851
RKD-IT
Re: Better freezing options
Postby Maxim » Fri Sep 29, 2017 11:08 am
Hello RKD-IT!
There is freeze pane only. There is no anything like this.
Return to Document Server
