HTTPS config is overwritten after update
Postby simsala » Tue Aug 01, 2017 8:35 pm
I configured the OnlyOffice-Server to use a HTTPS connection as described here: http://helpcenter.onlyoffice.com/server ... https.aspx
But it happens regularly that the configuration is lost after an update of OnlyOffice via apt-get. So OnlyOffice is not working after the update and I have to configure all again. (It happened for example with the last update, which I received at 25. July).
How can I use HTTPS without the need to reconfigure it after an update again and again?
simsala
Re: HTTPS config is overwritten after update
Postby Maxim » Wed Aug 02, 2017 8:29 am
Hello simsala!
It's a bug! We are planning to fix it in future releases. Thank you for the information!
Postby simsala » Thu Aug 03, 2017 8:48 pm
Ok, thats great to hear, thanks for the fast reply!
simsala
Postby Maxim » Fri Aug 04, 2017 6:14 am
Hello simsala!
Please inform us about all strange things you will notice.
Postby simsala » Thu May 31, 2018 4:00 pm
The problem still exists...
simsala
Postby Maxim » Fri Jun 01, 2018 6:41 am
Hello simsala!
1. You can backup nginx config
2. Please specify how you update your Document server.
3. What is the current version of the Document Server?
Return to Document Server
