BUG: Common Documents unread count
Postby worraps » Mon Apr 03, 2017 6:28 pm
User sees 50+ documents that have a change status. However, opening the "Common Documents" folder displays no unread changes.
Attempting to click the red box causes an error. "An item with the same key has already been added."
The user can not dismiss the change count.
By the way... Is there a better place to report bugs?
Great work on this project!
Single Server Installation
Docker on Ubuntu 16.04.2 LTS
Community Server: 8.9.2.27
Document Server: 4.2
https://github.com/ONLYOFFICE/Docker-CommunityServer
https://github.com/ONLYOFFICE/Docker-CommunityServer/blob/master/config/nginx/onlyoffice-ssl
worraps
Re: BUG: Common Documents unread count
Postby Maxim » Tue Apr 04, 2017 8:20 am
Hello worraps!
Thank you for your bug notification!
We are going to release 9.0 soon and there will be bugfix.
Return to Community Server
