Suggestion: Document tags
Postby Moinois » Sun Feb 05, 2017 6:53 pm
One thing that would help immensely would be to be able to tag documents and then to filter on tags when looking for documents. So if a document is uploaded and tagged it can be found regardless if the folder structure is made in a certain way or not.
Best regards,
Magnus
Moinois
Re: Suggestion: Document tags
Postby Maxim » Mon Feb 06, 2017 7:21 am
Hello Moinois!
Do you mean to tag a document like in Instagram for example? Name of the file is not enough?
Postby Moinois » Mon Feb 06, 2017 12:56 pm
Yes, like in adding meta data to be able to find specific documents that contains references to the same topics for instance, or setting a tag to display status. Just like in the mail client where you can add tags to a mail for follow up or if it is a lead. Just a great way to keep tabs on the documents without having to clutter the file name with meta data.
Moinois
Postby Maxim » Mon Feb 06, 2017 3:12 pm
Thanks for your suggestion! We will try to accommodate your wishes.
Return to Community Server
