Invoices – Quantities
Postby nillenille2 » Fri Dec 09, 2016 2:16 pm
It would be awesome if you could enter fractions in the "quantity" field of an invoice. This way we would be able to charge for half hours instead of only full hours of different services.
Thanks!
nillenille2
Re: Invoices – Quantities
Postby Maxim » Mon Dec 19, 2016 8:33 am
Thank you for your suggestion!
The field "quantity" means quantity of items in invoice. And i suppose you should create new item with half hours and select that new item.
Return to Community Server
