Order of contact information
Postby nillenille2 » Wed Oct 26, 2016 10:57 am
Hi.
It would be nice if the CRM system would support different locales, e. g. the 'state' field in CRM contacts and invoices should say 'Deutschland' instead of 'Germany'. It would be great if you were able to change the order of the address elements, too. I need name, street, zip code, city, state.
Thanks!
nillenille2
Re: Order of contact information
Postby Maxim » Fri Dec 02, 2016 8:29 am
Thank you for your feedback! We will take it into consideration!
Return to Community Server
