reference to another workbook
Postby sabrent » Fri Aug 19, 2016 4:08 pm
I have not been able to locate if we have the ability to reference another workbook within the OnlyOffice system. This would be a huge option for us, we could then share multiple individual workbooks and the pull the information from these workbooks into a single workbook for reports.
Is this already in place or how would I suggest this as a option to bring into the system?
sabrent
Re: reference to another workbook
Postby Eugenie » Thu Aug 25, 2016 3:12 pm
Unfortunately it is not possible at the moment. Thank you for the suggestion
Eugenie
Postby worraps » Mon Apr 03, 2017 5:56 pm
+1 - This would be very helpful
sabrent wrote:I have not been able to locate if we have the ability to reference another workbook within the OnlyOffice system. This would be a huge option for us, we could then share multiple individual workbooks and the pull the information from these workbooks into a single workbook for reports.
Single Server Installation
Docker on Ubuntu 16.04.2 LTS
Community Server: 8.9.2.27
Document Server: 4.2
https://github.com/ONLYOFFICE/Docker-CommunityServer
https://github.com/ONLYOFFICE/Docker-CommunityServer/blob/master/config/nginx/onlyoffice-ssl
worraps
Postby Maxim » Tue Apr 04, 2017 6:58 am
Hello worraps!
Great idea! Thank you for your feedback
Return to Community Server
