Hi All,
I have delete my previous docker instance:
sudo docker rmi -f $(sudo docker images | grep onlyoffice/documentserver | awk '{ print $3 }')
When i run the following command I verify that I have the 8.9 version of the community server:
sudo docker run -i -t -d -p 80:80 --name oo-comm-serv onlyoffice/communityserver
However, when I link to my existing datasources using the following command:
sudo docker run -i -t -d -p 80:80 --name oo-comm-serv \
-v /opt/onlyoffice/CommunityServer/logs:/var/log/onlyoffice \
-v /opt/onlyoffice/CommunityServer/data:/var/www/onlyoffice/Data \
-v /opt/onlyoffice/CommunityServer/mysql:/var/lib/mysql \
-v /opt/onlyoffice/WebStudio:/var/www/onlyoffice/WebStudio onlyoffice/communityserver
I'm back to version 8.6....
Any ideas?
