Add A SVG Editor
Add A SVG Editor
Postby Xarcell » Thu May 05, 2016 12:46 pm
This is a request to add a svg editor so that companies can work on branding/identity. There is an excellent MIT licensed robust svg editor here to get you started: https://github.com/SVG-Edit/svgedit
Xarcell
Re: Add A SVG Editor
Postby Alex » Wed May 11, 2016 2:42 pm
You can use any third part applications for creating the logos, the files can be uploded from your server and applied on the portal.
There is also a custom build option available with all your logos included.
Contact sales@onlyoffice.com for additional information, white label option is available for Onlyoffice Integration Edition users
Alex
Return to Community Server
