Community server - Email Agrigator not working any more
Postby Riebens » Thu Aug 16, 2018 12:35 pm
In the log file, the following message shows?
2018-08-16 12:07:51,249 INFO MainThread : Tenant 1 payment cache is expired.
I was not aware of email limits on the Community edition?
Any guidance would be appreciated
Riebens
Re: Community server - Email Agrigator not working any more
Postby Maxim » Mon Aug 20, 2018 1:50 pm
Hello Riebens!
There is no email limitation.
This is just INFO message.
If your email aggregator is not working you should find a reason. Please take a look at the logs. Or enable extended logs.
docker exec -it onlyoffice-community-server sed -i 's/<level value="WARN" \/>/<level value="ALL" \/>/g' /var/www/onlyoffice/WebStudio/web.log4net.config
docker exec -it onlyoffice-community-server service monoserve restart
Return to Community Server
