Exporting the Wiki
Exporting the Wiki
Postby randomstranger » Tue Jun 26, 2018 12:18 pm
Playing around with the Wiki, I was wondering whether there is an easy way to export the Wiki. Where does OnlyOffice store the data created in the wiki? I took a look at /var/www/onlyoffice/Data/Products/Community/Modules/Wiki/Data (Linux), but pretty empty as far as I can tell (we've created a dozen or so articles).
Is OO's Wiki based on https://www.mediawiki.org/wiki/MediaWiki? If so, I'd be interested in moving the data between OO and MediaWiki. Generally, the idea is to be able to easily move data from one Wiki solution to another.
Thx
randomstranger
Re: Exporting the Wiki
Postby Maxim » Wed Jun 27, 2018 8:03 am
Hello randomstranger!
All wiki pages are stored in database (wiki_categories, wiki_comments, wiki_files, wiki_pages, wiki_pages_history).
Postby randomstranger » Thu Jun 28, 2018 6:39 am
Hi Maxim
Thanks for the quick reply. Of course, I was thinking in terms of DokuWiki which doesn't use a DB. So basically a mysqldump. I guess something like this https://www.mediawiki.org/wiki/Manual:Backing_up_a_wiki should do the trick.
Thx again & cheers
randomstranger
Postby Maxim » Fri Jun 29, 2018 8:11 am
I hope it will work.
Return to Community Server
