Log file for failed login attemps
Postby randomstranger » Sat Apr 21, 2018 11:26 am
Where does the Community Server store the log file(s) for failed login attempts? I've gone through both /var/log/onlyoffice and /var/log/nginx, but couldn't find anything.
Thx
randomstranger
Re: Log file for failed login attemps
Postby Maxim » Thu Apr 26, 2018 12:57 pm
Hello randomstranger!
Is there a problem?
Log files are in /var/log/onlyoffice
Postby randomstranger » Fri Apr 27, 2018 5:18 am
Hi Maxim
Yes, all the log files are indeed in /var/log/onlyoffice, I just can't figure out which log file (there are quite a few!) is storing failed login attempts. I've gone through nginx.error.log which is empty, access.log which doesn't seem to contain anything regarding failed login attempts...any ideas?
randomstranger
Postby Maxim » Sun Apr 29, 2018 8:15 am
Login actions are not loged in logs. There is Login History in the Control Panel. These data downloads from database
Postby randomstranger » Tue May 01, 2018 1:01 pm
Hello Maxim
That's what I thought. Basically, the login history is only available for the Enterprise version, am I correct? The reason I'm asking is because I'd like to harden the security a bit with fail2ban, but in order to set it up I'd have to point it to the appropriate log file (logging failed login attempts). Could this be implemented for the Community Server?
Cheers
randomstranger
Postby Maxim » Fri May 11, 2018 11:12 am
I cannot say now, i will redirect your request to our developers.
Postby randomstranger » Fri May 11, 2018 2:14 pm
Thanks!
randomstranger
Postby Maxim » Tue May 15, 2018 11:06 am
Thanks!
You are welcome!
Return to Community Server
