Concurrent User Login
Postby annimeshraj » Tue Apr 17, 2018 9:55 am
Hi
If I setup Community Server then how many users can manage there documents concurrent(at the same time).
Cheers
Animesh
annimeshraj
Re: Concurrent User Login
Postby Maxim » Thu Apr 19, 2018 11:14 am
If you installed Community Edition document server is able to work with 20 simultaneous connections (sessions). The 21 session will be in view mode only.
Return to Community Server
