Start/stop timer
Start/stop timer
Postby cantabrico » Fri Jan 05, 2018 9:12 am
I have one problem.
1. I run the start stop timer
2. I see the Save button
3. I will write a long description.
4. I do not see the save button and can not be saved or scrolled. The only option is to change the window size.
Re: Start/stop timer
Postby Maxim » Tue Jan 09, 2018 8:11 am
Hello cantabrico!
Thank you for feedback!
Return to Community Server
