Sorting Projects
Sorting Projects
Postby cantabrico » Thu Dec 14, 2017 2:14 pm
Hi.
I have a little problem.
I will set up the sorting of projects by name. When I click on the jobs and go back to the projects, everything is OK. Sorting by name. But when I click on My Projects, it changes everything to sort by date. Nothing helps. How do I set default sorting by name?
cantabrico
Re: Sorting Projects
Postby Maxim » Fri Dec 15, 2017 7:15 am
Hello cantabrico!
Thank you for the information! I have tested it on my installation and have found no problem. Specify please your version of Community Server.
Postby cantabrico » Fri Dec 15, 2017 1:30 pm
Hi.
9.5.1.517
Step 1. Open: .../products/projects/projects.aspx and my adress is: .../products/projects/projects.aspx#sortBy=create_on&sortOrder=ascending
Step 2. Change by title
Step 3. Click My Projects (automatic is sort by Creation date)
Step 4. Change in My project sort by title
Step 5. Click Projects -OK
Step 6. Click My project again (sorting by date)
cantabrico
Postby Maxim » Tue Dec 19, 2017 7:07 am
Hello cantabrico!
Thank you a lot for your feedback. We will fix this issue.
Return to Community Server
