Ability to create a new document from the folder view
Postby Nepu » Sat Nov 18, 2017 9:24 pm
I've installed OnlyOffice on my server today and I'm pretty impressed by how well it handles Microsoft Office documents and by how well it works in general. Much better than LibreOffice
One thing that feels kind of awkward however is that you can only create a new document from the document editor, and only the kind of file that you've already had open. It would be great if you could right click on the "My Documents" page on the community server and then select "New" and then "Spreadsheet", "Document" or whatever to create an empty one.
Nepu
Re: Ability to create a new document from the folder view
Postby Maxim » Tue Nov 21, 2017 7:38 am
Hello Nepu!
Thank you for your suggestion!
We will take it into account.
Return to Community Server
