Using Draw.io in onlyoffice community server
Postby reklawyks » Fri Oct 20, 2017 8:45 am
I was wondering if there are any plans for 3rd parties integrations. I would like to be able to edit draw.io documents for example. Is there a way to do it already, like have the files managed by the commutiny server and have them opening directly with draw.io. Or could it be a plugin that directly integrates it into onlyoffice. Or are there plans to have a diagramm app added to onlyoffice?
Thanks for your help
Rico
reklawyks
Re: Using Draw.io in onlyoffice community server
Postby Maxim » Mon Oct 23, 2017 6:15 am
For now we didn't plan to implement support of Draw.io. As i understand you would like to have a possibility to integrate diagrams into docx file?
Postby reklawyks » Mon Oct 23, 2017 7:14 am
Hi Maxim,
Thanks for your reply.
The idea is not so much as du integrate them in doc files, but to use standalone draw.io (xml) files and manage them through onlyoffice (just like any doc, xls or ppt file).
reklawyks
Postby reklawyks » Wed Nov 01, 2017 10:55 am
Do you have any documentation on creating integrations/plugins for onlyoffice?
I imagine something simple like if file extension is Y open it using X, as draw.io is an online editor this kind of integration should be quite easy to do? (or maybe I'm talking about something I don't understand as I'm not even a dev... :roll: )
cheers
reklawyks
Postby Maxim » Fri Nov 10, 2017 8:04 am
Hello reklawyks!
There is onlyoffice api, maybe it will help you, but i doubt.
Return to Community Server
